Don Harry
Just confirmation of bugs
Fri Jan 18, 2019 7:49 am
the wifi is useless under MESH situation, by connection with 2,4 GHz + 5 GHz connention wll get lost.
Fingerprint stops working after random time, the visible fingerprint symbol starts shaking and the function is no to use until restart.
csewell
Re: Just confirmation of bugs
Sat Jan 19, 2019 3:10 pm
Good, it's not just me seeing this, so the chances are good it can be fixed with an update.
BV6000
Sat Feb 09, 2019 10:00 am
another bug, When the screen increases or decreases the intensity of the brightness, a delay or lag occurs
chrisb
Tue Mar 19, 2019 10:13 am
A hardware bug, it leaks. I have 4 BV phones, I have used all in the spa and pool. This is the only one that leaked first dunking. I have also had phones from other brands which didn't leak either
