I purchased the phone to use the UHF radio built in but it is lacking some features that would be nice to have & add functionality to the phone.
One would be to add the ability for "tones" when editing a channel. This is used for repeaters. I have been unable to get a repeater to work on the app due to this.
The other would be to add a digital Morse Code ability. Set it up so you can type a message & tap send, then it sends out as a Morse Code. Then, have a setting to translate the Morse code when it is received. This would be extremely helpful in man situations.
