What is the maximum capacity of a microSD card that can be used with the BV9500 (simple one, not the PRO) ?
Regards,
Chichoun
csewell wrote:I put a 256 GB card in mine and it worked fine.
Martino wrote:csewell wrote:I put a 256 GB card in mine and it worked fine.
Hi, this can work but be careful.
If the manufacturer recommends 64GB it is because they are sure to handle them. If you exceed this threshold, you may experience problems with data loss in the future.
This generally applies to all devices of all manufacturers.
Chichoun wrote:Hello,
Regards,
Chichoun
F.E.K. wrote:Chichoun wrote:Hello,
Regards,
Chichoun
I have 128Gb MicroSd card in my phone, working well.
