coonrado
Waterproof plug for USB C socket
Mon Jan 07, 2019 8:11 am
Are there USB C plugs available for BV9500Pro?
Re: Waterproof plug for USB C socket
Tue Jan 08, 2019 4:49 pm
No need for that, as the USB C socket has been sealed inside ;)
These plugs aren't 100% full seal, by the way ;)
coonrado
Tue Jan 08, 2019 5:46 pm
The plug could also protect against dust and dirt I think.
Thu Jan 10, 2019 3:25 pm
The phone got rated IP68, IP69K and Mil-std, it is sealed against everything ;)
CallMeColt
Tue Jan 15, 2019 5:06 am
With the port being waterproof, if it were to get so dusty, you could simply rinse it out. Maybe even a burst of air from a duster.
Cilone
Mon Jan 28, 2019 5:36 pm
Or a very thin pin with cotton and isopropilyc alcohol.
