Priyanga
WiFi reception
Sun Jan 06, 2019 3:03 pm
I have bv6000 for 18 months.I noticed that bv6800 WiFi reception is lower than bv6000.somebody else noticed that.or admin can check with blackview team.thanks
grAwp
Re: WiFi reception
Mon Jan 07, 2019 10:07 am
If I compare BV6800Pro and BV7000Pro (which I used more then 1,5 year), so BV7000Pro has a better gain from WiFi signals but weaker GPS signal with comparison to BV6800Pro.
Re: WiFi reception
Tue Jan 08, 2019 4:52 pm
A lower wifi reception can't be considered an issue until it is extremely low. Too many variables behind it!
