Priyanga
Battery usage
Tue Jan 01, 2019 9:24 am
Can someone help me to see battery usage time,display yse and other apps used battery.and battery discharge graph.thanks
jangbv
Re: Battery usage
Tue Jan 01, 2019 12:08 pm
You are looking for this?
Found it by searching settings. Don't know actual path to it tho.
Priyanga
Re: Battery usage
Thu Jan 03, 2019 7:13 am
Yes this is the one.how you go to that? Thanks
grAwp
Re: Battery usage
Fri Jan 04, 2019 8:34 am
Install this application : AccuBattery.
But you must it run manually after each boot android. It is still not fixed via update - automatically run after boot.
wilczur
Re: Battery usage
Fri Jan 18, 2019 10:32 pm
Can You give link for this app?
Re: Battery usage
Mon Jan 21, 2019 9:21 pm
Just search for it in the play store ;)
