rudyong
[TRACKED] All Apps not Autostart
Sat Dec 08, 2018 11:17 pm
I found out that all the apps not start, after the phone turn on
I must tap on the icon of the apps to turn apps on.
Apps like Whatsapp, BBM, facebook, and all the apps i installed from play store.
It is weird.
Please fix this immediately
Thank you
Re: All Apps not start
Sun Dec 09, 2018 9:23 pm
Hi there! First perform a factory reset, then allow such apps to run in background (press the menu button in the lower part of the display, then go to settings about that).
Please check this:
https://www.google.it/amp/s/forums.andr ... html%3famp
sams
Tue Dec 11, 2018 3:09 am
I noticed the same behavior. Factory reset did not help.
No auto-start application works at startup (not even the alarm !)
If you check in developer options>Running services, you can see that the services of every startup apps are running but they are somehow inactive and not starting the front end applications (no notifications for example).
You need to start every single one manually at every startup/reboot.
Once you started them, they works without any problem and they don't get killed by Android.
All is good until you shutdown or reboot the phone. Then you have to restart all your startup apps again...
This is clearly a bug.
Temporary workaround : putting an active widget of the application apparently helps it to auto-start correctly.
grAwp
Wed Dec 12, 2018 11:47 am
On my BV6800 same problem. AccuBattery app didnt start after boot, every time I must manually start this app. I think this rule is on all apps.
Messenger not coming messages, only if I open it. Then come all messages.
Fix it please.
grAwp
Wed Dec 19, 2018 6:01 am
It can be fixed or not ?
Wed Dec 19, 2018 7:50 am
Try to select "don't optimize the app" in battery optimization settings, and report back.
sams
Wed Dec 19, 2018 10:49 am
Already tried. Changed nothing.
grAwp
Wed Dec 19, 2018 11:48 am
I already tried. Nothing changed. It is software problem.
Thu Dec 20, 2018 7:28 pm
Ok, I'm forwarding such issue to the tech team for a software fix.
jangbv
Re: [TRACKED] All Apps not Autostart
Wed Dec 26, 2018 11:17 am
Hey.
Have you looked under "System Manager" > "App autoboot" ? By default all apps are disabled there.
