Chimera123
Change Themes and Icons
Wed Dec 05, 2018 6:13 pm
Hello, I just got my phone,
I see the the Android is NOT stock and comes with weird looking icons + top notification bar is black + a few games installed like Spiderman etc...
First of all, don't take it personally but this is not nice and the design is not as pretty as stock android
Is there a way to install a theme with new icon designs???
to make it look like it should be without changes?
Thank you!
Re: Change Themes and Icons
Wed Dec 05, 2018 11:54 pm
Hi there! Just use apps like novalauncher to customize your home and theme :)
Chimera123
Thu Dec 06, 2018 9:31 am
Yes I will probably do that, but changing the top notification bar design n icons. and system icons is a harder, if you have any idea for that, or a launcher that can do that I would love to know.
Thanks
sams
Fri Dec 07, 2018 2:01 am
+1
and those blue balls in the quick settings are absolutely unreadable.
Go on tell me what you see without putting your phone IN your face.
Please revert to the stock ones !
PS : don't forget to fire the person who did that :)
Sat Dec 08, 2018 10:25 pm
Thanks
You can also do that with novalauncher app.
Chimera123
Tue Dec 11, 2018 9:06 am
Just for others to know,
I used the app Power Shade to change the notification bar,
As a louncher I'm using lightning louncher..
To blackview, If you have an option to change it to stock, in the next update, it will be great!
I'm sure that if youll make a poll here nobody will like this weird and unfunctiinal design.
I am talking about:
that every app icon on the desktop gets a square mask with colors
and settings screen icons
Tue Dec 11, 2018 4:59 pm
I am talking about:
Thanks for your feedback!
bcros
Wed Feb 13, 2019 11:31 am
I also agree. Almost Oreo launchers let shape the icons as the user wants. Anyway, it is too bad to have keep the circle...
The phone is good, let give it all the android powered featured it must have.
Bruno
EnGy
Thu Mar 14, 2019 3:23 pm
It will be usefull if you make in status bar "NFC" button like Sony Xperia.
hspencer
Fri Apr 26, 2019 1:55 am
sams wrote:
+1
+1000
Totally agree. These iconos are unreadable. Please change them ASAP
