dimitrisalembier
BV6000 general issues
Tue Jul 19, 2016 6:24 pm
Does anyone has the same problems as I encounter :
a) gyro does strang things (already a few topics about it)
b) light detector seems to have problems handling indoor light (goes bright, dark, bright, dark, ...)
c) missing app-drawer, everything is appearing on the startscreen, (installed appdrawer-app, but it should excist in the rom)
d) not possible to remove links from the startscreen (those restrictions are a pain in the ass if you want a clear-desktop)
e) usb-connection is not standard micro-usb, they are longer .... (in my car I have a 2m long connection cable to reach the windscreen, no I cannot use it anymore)
f) the panorama function from the camera looks like something that is build in the early 80's, the picture you make isn't good at all... (for developers, look at the camera-app in a sony xperia Z1, this one does it verry well ...
g) battery (or something else) seems not fixed inside, if I shake the phone you feel it shaking and hear it make a knocking sound
If you seem to have the same problems or other ones it would be handy to get some reply.
woedie
Re: BV6000 general issues
Wed Jul 27, 2016 8:52 pm
I didn't found out all issues yet, I hope I don't find them...
A comment about topc c: I like the way the apps are organized
I have also something lose when I shaked the phone. When you tap the left lower corner you notice it is lose somewhere. I saw a video and there you see it is the speaker that is located there.
I also want to add the very poor sound when you take a picture. I also have some doubts about the battery but need more time to figure this out.
So doesn't meet all expectations.
