pityko
proximity sensor not worked
Sun Jan 31, 2016 2:35 pm
Unfortunately, the proximity sensor is not working. :(
If I'm calling to be careful to not press against the menu.
No this function does not work-related.
no gallery move, music player move, and no unlock
I install the sensor test.
The app write:
-Vendor: MTK
-Version 1
-Max renge: 1cm
-resolution 1cm
-curent: 0,13mA
What can I do now?
thanks
Re: proximity sensor not worked
Mon Feb 01, 2016 6:28 am
hi ,
could you show your problem via some pictures or a video ?
Best regards,
Admin
