AleP
Adapter USB C from gasket to normal USB C
Tue Nov 20, 2018 8:38 pm
Is there a way to buy an adapter form USB C of the Bv8000 Pro to normal USB C.
It is safe use a normal USB C with the charging board of the BV8000 PRO?
Can you send any link if you find it?
Thanks.
Re: Adapter USB C from gasket to normal USB C
Wed Nov 21, 2018 1:51 am
Unfortunately not, I reccommend you to buy some original spare cables: they are good and cheap, and can be used also with other phones (with a shorter usb c port) :)
https://www.aliexpress.com/item/New-Tra ... bf4cdc577a
https://www.aliexpress.com/store/282102 ... Text=cable
AleP
Wed Nov 21, 2018 7:25 pm
Sat Nov 24, 2018 3:27 am
A normal USB-C cable won't fit. It's head is too short!
AleP
Sat Nov 24, 2018 11:30 am
If a normal USB C cable works with my Bv8000 Pro I can use it without damaging anything?
Sat Nov 24, 2018 10:19 pm
Yes.
