nikko
BV 5800 Pro bricked
Sun Nov 18, 2018 3:21 pm
I got a BV5800 Pro bricked.
Im not a newbie with Android terminals but im stuck with this one !
I cant communicate anymore with SP Flah Tools, i tried to restore an image from an other BV5800 Pro but i still got the message : ERROR : STATUS_DA_HASH_MISMATCH (0xC0070004)
I can connect with other BV5800 but not on this device, i cant anymore ... Do you think i have to send it to support or do you have any idea ?
It seems i had this message after formating the device ...
Thanks for you reply
Re: BV 5800 Pro bricked
Sun Nov 18, 2018 8:56 pm
I suggest you to contact your seller to have your device replaced under warranty.
dvortex
Sun Nov 25, 2018 12:10 pm
nikko wrote:
I have the same problem. Did you found a solution?
CMV261094
Tue Nov 27, 2018 11:27 pm
sorry to hear that. :cry: :cry: :cry: You probably forgot to untick the preloader. That's what i've done with my BV5800. So the result is a faultly memory adresses. This error cannot be fixed. You need to change the motherboard.
Thu Nov 29, 2018 12:07 am
Please remember that rooting can't be officially supported for obivous reasons, and that it may void your warranty.
