I do not recive the notification if the apps are not open (screen on).
Gmail emails arrive to me an hour later.
I have always used oruxmap to record the path during the run but if I use oruxmap with the bv9500 I have to keep the screen on, if is in the background it does not record the GPS position. I have the same problem with other apps, it seems that the background apps can not work.
Aby suggestion?
Thanks for your help
