Siddhu8990
NFC-Felica in BV9500Pro
Tue Nov 13, 2018 8:43 am
During Indiegogo campaign, I had specifically if NFC used in BV9500 Pro is NFC-F compliant or not. Campaign owner had replied that it is compatible and I will be able to use to for POS payments in japan. But in actual it is not NFC-F but just NFC. Can you confirm that? I'm not able to use the apps which need NFC-F and not just NFC.
Re: NFC-Felica in BV9500Pro
Wed Nov 14, 2018 7:31 pm
Unfortunately NFC-F isn't supported. Only normal NFC. I'm sorry.
