Patsix
[SOLVED] BV9500 Manage Home screen
Sun Nov 11, 2018 5:27 pm
Is there a way to move or delete, on the main screen, the google search window?
All the other item can be move to another screen, but not this one?
Thanks in advance
Re: BV9500 Manage Home screen
Mon Nov 12, 2018 10:39 pm
Patsix
Tue Nov 13, 2018 8:22 am
Thank you for this quick reply.
I thought it was a specific problem with Blackview, but with the links you  mentionned, I see that it's an Oreo problem.
So I googled severy web site, and finally, I suppose the best way is to use an alternate launcher.
Regards.
Patsix
Tue Nov 13, 2018 9:16 am
May I suggest Lawnchair app .
It's very light and have a lot of settings. (free without ads) :mrgreen:
Ramrod
Tue Nov 13, 2018 11:56 am
afaik, you need to use a launcher like Nova Launcher since the google search bar is otherwise embedded in the home page. Can't otherwise be moved .
