AleP
The higer part of the display doesn't work.
Fri Nov 09, 2018 6:04 pm
No new apps installed or firmware updated, any advice?
Re: The higer part of the display doesn't work.
Sat Nov 10, 2018 6:41 am
Hi there! First try to perform a factory reset. if doesn't solve your issue, you'll have to replace the LCD/digitzer unit. You can find it here:
https://www.aliexpress.com/af/blackview ... y&jump=afs
