nicobt2f
Change Vibrations
Wed Nov 07, 2018 1:15 pm
Is there an option to change the phone vibration ? the vibrations are very weak.
Thank you :)
Re: Change Vibrations
Sat Nov 10, 2018 6:49 am
hi there, you can try to increase it using the engineering menu.
Dial:
for the regular version:  *#87#
"Pro" : *#*#33#*#*
emariu
Sat Nov 10, 2018 9:13 am
How to change / increase vibration in engineering menu ?
There are only testing functions, I didn't find any way to set/change functions ?!
Sat Nov 10, 2018 10:45 pm
phoenixkk
Tue Nov 13, 2018 11:11 am
blackview_admin wrote:
There is no such settings, Can you point me specific menu for change vibration intensity. b'coz mine is very low too.
Users browsing this forum: Google Adsense [Bot] and 4 guests
