  • 1
  • 2
  • 3
  • 4
  • 5
  • 8
tiboponpon
[TRACKED, WORKAROUND FOUND] Reboot
Mon Nov 05, 2018 1:10 pm
Hello. I have a problem with my bv9500 pro.
I regularly and several times a day blocking and restarting the phone.
Very randomly.
The problem occurs mostly after a time after unlocking.
I put in factory configuration several times without success.
What are the possibilities to solve this problem.
Thank you. Cordially.
Re: Reboot
Tue Nov 06, 2018 4:51 pm
Can somebody else confirm such issue please?
In the meantime, try to disable Duraspeed and report back
Ramrod
Re: Reboot
Tue Nov 06, 2018 4:57 pm
I get that when I launch one of my apps. I therefore don't use that app anymore.
tiboponpon
Re: Reboot
Tue Nov 06, 2018 5:14 pm
Hello. The problem occurs with any application or even sometimes at night.
Often times after a wakeful exit. In activity supported much less problem.
unless I juggle very quickly between several applications.
tiboponpon
Re: Reboot
Wed Nov 07, 2018 8:30 pm
Hello. The problem is very unstable.
How can I reinstall the original software if it is defective.
Do you have a local update.
Thank you.
Parcheval
Re: Reboot
Thu Nov 08, 2018 9:13 am
which app? Would be interesting to know
Ramrod
Re: Reboot
Thu Nov 08, 2018 12:38 pm
Re: Reboot
Sat Nov 10, 2018 10:37 pm
Thank you.
Just perform a factory reset. Follow this tutorial CAREFULLY.
viewtopic.php?f=192&t=334922
tiboponpon
Re: Reboot
Sun Nov 11, 2018 8:18 am
Factory reset several times.
Without success.
No particular applications seem to be involved.
Very random problem. Can be restarted 5 times in a row like 0 in the morning before restarting.
Can also restart the night ....
By cons never had a problem on heavy applications. I can play 2h a Pubg without any problem ...
Ramrod
Re: Reboot
Sun Nov 11, 2018 5:07 pm
My phone rebooted by itself today. I was using Spotify at the time but I don't know if that's got anything to do with the reboot.
  • 1
  • 2
  • 3
  • 4
  • 5
  • 8
