Wolpertinger
New ROM-Versions
Sun Nov 04, 2018 12:43 pm
For general information:
I got 2 new ROM versions per OTA within a few days.
20180612 and a little later 20180711
For both versions only "some small bug fixes" were announced.
The state of the security patches has not changed. It is still 05.Feb 2018.
custal
Re: New ROM-Versions
Tue Nov 06, 2018 8:08 am
And I still get "you're up-to-date" though I'm on 20170708 ... :(
Needless to say, flashing does NOT work either :evil:
iMacOSX
Tue Nov 06, 2018 11:40 am
i update to  20180708 and my phone not ringing and play sound's in applications!!!
I reset setting to factory but not help this!!
Any sugestion??
Costantino
Tue Nov 06, 2018 5:48 pm
Everything fine. Thanks I appreciate
hersche
Sun Nov 11, 2018 8:31 pm
somehow, i can't flash anymore, it stucks on "Download DA" - but the current system is simply untouched, so not a issue, since it's working.
But i am stuck at 20180711 as well. While it seems here, there is never OTA-stuff out AND i cannot flash via SP-flash-tools, it would be pretty cool to have some local updates possible in the official links-post.
I hope, the admin here will go for it. I have some system-issues which would be very cool if they're gone.
EDIT: Meanwhile, the flash-problem is solved and i've upgraded to the needrom-avaible one. viewtopic.php?f=144&t=475404
custal
Tue Nov 13, 2018 8:42 am
Don't count on it. I for one have given up on BlackView. A shame, really.
I totally digged by BV6000.
