Yamach
[USEFUL] About camera lens replacement
Sat Nov 03, 2018 9:55 pm
I bought the model blackview 9500 I broke the lens of the rear camera the glass that protects the camera. It is possible for me to sell the replacement
Re: Camera lens replacement, Yamach
Sat Nov 03, 2018 11:37 pm
Hi there! You will find it here: https://m.it.aliexpress.com/wholesale/B ... eplacement
You have to buy the whole back cover.
Yamach
Thu Nov 08, 2018 4:29 am
the housing does not have the glass of the camera. where can I get it?
bpz1970
Sat Feb 09, 2019 1:55 am
Hello! Is there any instructions on how to replace the rear camera lens glass? Is it mandatory to open the rear cover? Thanks in advance for the answer!
Wed Feb 13, 2019 9:00 pm
It doesn't seem to be necessary.
ferluci
Thu Mar 28, 2019 7:55 pm
Did you manage to insall the camera glass?, I´ve received it by mail today, but noticed there´s no glue or whatsoever to atach it to the phone....
Tech Addict
Mon Apr 01, 2019 1:37 am
I just replaced mine over the weekend and mine included a foam rubber adhesive pad. If yours didn't you might want to go back and double check the item listing wherever you bought it to see if it was supposed to include it. It will be necessary. Perhaps you can find a generic adhesive foam pad somewhere and cut your own, but that'll be a big PITA.
Mine came direct from BV, as a warranty replacement item. I also had to replace my speaker. I recorded it all on video but you probably won't want to watch -- there are five in a series of about an hour and a half total length. I think the fourth one was the one where I showed the actual pad being installed followed by the glass...
https://www.youtube.com/playlist?list=P ... SO59jHcPJM
Hope it helps.
ferluci
Mon Apr 01, 2019 12:00 pm
Hope it helps.
Hi there. My replacement came alone, no adhesive at all. Thanks for your comments, I´ll chech the videos on youtube right now. You know, as soon as I received the phone and checked out my new "toy" I realized of that piece being broken in no time, because, as you surely noticed, that tiny glass is the first thing hitting the floor when falls on its back part. I think I´m gonna atach some rubber gasket around this piece to avoid direct hits. Thank you again.
Users browsing this forum: Google Adsense [Bot] and 7 guests
