Ramrod
USB-C Wall Charger plug rating for BV9500?
Sat Nov 03, 2018 6:50 pm
Hi all.
I'm after buying more fast chargers for my BV9500.
It's easy enough to buy fast type-c cables but things get a little trickier when trying to decide on a wall charger plug.
They have all sorts of different ratings (27W/30W/41W etc.....)
What's the best spec for the BV9500?
Would it matter if I buy a 100W and plug my phone into that? Would it damage the phone?
edit: btw, I unboxed my phone 5 days ago and have just put it on charge this evening for the first time as it got down to 10%.
I'm VERY happy with the battery life! Great product! :)
Re: USB-C Wall Charger plug rating for BV9500?
Sat Nov 03, 2018 11:42 pm
Hi there.
You'll have to buy a charger rated 5V-7V-9V-12V 2A which supports the Mediatek pump express protocol (not the Qualcomm quickcharge one)
Ramrod
Sun Nov 04, 2018 2:42 pm
blackview_admin wrote:
Hi there.
Thanks for the info.
Do you think that I would damage the BV9500 battery if I was to use a 40-60V plug?
Tue Nov 06, 2018 4:12 pm
Hi there.
Yes, the phone may get damaged by that.
Ramrod
Tue Nov 06, 2018 4:40 pm
I won't do that then! Ta :)
Ramrod
Fri Nov 09, 2018 11:35 am
It would be great if sellers on Amazon etc actually mentioned what charging protocol their plugs use! Grrrr!
