papapedrox
[TRACKED, WORKAROUND FOUND] Proximity sensor
Fri Nov 02, 2018 10:15 am
I'm very happy about my new 9500 pro but I have a problem of sensibility of the proximity sensor while phoning. How can I calibrate it?
Re: Proximity sensor
Sat Nov 03, 2018 3:12 am
What's actually the problem?
Sat Nov 03, 2018 4:41 pm
Please, I need more details about such issue. In a decent English, if possible.
Neville
Sat Nov 03, 2018 10:26 pm
A couple of our customers have complained about this too...the proximity sensor only blanks screen during calls if sensor is fully touching skin to block light....if the slightest light gets in the screen comes back on and then the user can accidentally put calls on hold or mute with their cheek while talking.
Solution again would be for engineering to allow access to engineering mode as on previous Android versions so users can calibrate the sensor...
Sat Nov 03, 2018 11:54 pm
Great, will ask tech team about that ;)
Mon Nov 05, 2018 5:34 pm
Try *#*#33#*#*
Stratosphere
Wed Nov 07, 2018 2:15 pm
I have this problem too on the BV9500 (not PRO). *#*#33#*#* doesn't work for me ...
Sat Nov 10, 2018 10:29 pm
Try *#87# , it will work
Roni
Sat Nov 17, 2018 1:32 am
Admin, I'm wondering what the tech team said about this?
No where do I see any test or adjustments for proximity sensor.
If I don't flatten the phone screen to my cheek, the screen will light up, and the Mute button gets engaged.
Sat Nov 17, 2018 11:14 am
try  *#*#33#*#* or *#87# , it will work
