ityuuu85
Function key on the right side.
Thu Nov 01, 2018 1:39 pm
What is function this key? Can it be programmed? How?
Re: Function key on the right side.
Thu Nov 01, 2018 8:51 pm
It is for the camera ;)
serg2327
Fri Nov 02, 2018 4:10 am
Settings /Smart assistant /Shortcut button
ityuuu85
Fri Nov 02, 2018 8:15 am
Wooow. My language is described differently. Thanks for the help!
:geek:
Ramrod
Fri Nov 02, 2018 8:45 am
Thanks for that information.
Does anyone know how to map the shortcut button to the camera shutter?
Ramrod
Sat Nov 03, 2018 3:18 pm
It appears that in order to map the function button to the camera shutter, I need to root the phone :/
ityuuu85
Sat Nov 03, 2018 4:20 pm
Volume keys default
Ramrod
Sat Nov 03, 2018 6:44 pm
I realise that, but I want to map the shortcut button to the camera shutter.
Reason being that I can then double press the power button to open the camera and then use the programmable button to operate the shutter--without having to turn the phone around. I'll be wearing ski gloves and anything that makes the camera easier and quicker to use is good.
Pappmann
Thu Nov 15, 2018 12:45 pm
+1 i need the Function Button as Camera Shutter, the Volume Buttons are on the wrong place to make photos.
Roni
Sat Nov 17, 2018 1:19 am
I've had the short cut button (function key) on the lower right side as my camera button from day 1. I did exactly as described a few times already on above posts.
