Ellorion
[Sound Volume Adjustment] Sound too loud
Wed Oct 31, 2018 6:10 pm
Currently the lowest possible sound volume is too loud.
Too loud for music and especially for phone calls.
I am currently using an app to adjust that bevavoir,
but the volume buttons will overwrite that every time.
Is / will it be possible somehow to increase the steps of
the volume sliders to get better granularity
(maybe 30 or 45 instead of currently 15, which the hardware can handle)
or may there be another option like making the current setting half as loud
(the opposite of the already available "BestLoudness" setting in the sound settings menu)?
Thanks
Re: [Sound Volume Adjustment] Sound too loud
Thu Nov 01, 2018 9:12 pm
Hi there. Just press a volume button and then slide the volume level with your finger in the display ;)
Ellorion
Thu Nov 01, 2018 9:58 pm
That does not seem to work, since the volume inbetween the steps is as loud as directly on one of the 15 steps (the next available step with sound difference).
It is also inconvienent to adjust the volume on the screen when there are buttons for it.
Santpj
Fri Nov 02, 2018 3:26 pm
Impossible to go lower... There is in minimum and I can't go down
Ramrod
Fri Nov 02, 2018 5:33 pm
Perhaps you have "BesLoudness" on?
settings>sounds>advanced>sound enhancement>BesLoudness
(That's not a typo, I presume it's meant to be "BestLoudness" but someone didn't spell it correctly) :D
Sat Nov 03, 2018 3:18 am
Can anybody else confirm such issue? Can you guys provide a video of it and a video of you adjusting volume by touching the slider?
Santpj
Sat Nov 03, 2018 11:56 am
I tried this morning WhatsApp videocall with Besloudness off..... Same thing... Too loud
Stratosphere
Thu Nov 15, 2018 12:17 pm
I think the recent update fixed this, my volume levels are much better now.l
Thu Nov 15, 2018 9:05 pm
Great! problem solved ;)
