mathatter
Broken Glass
Tue Oct 30, 2018 3:10 pm
I broke the glass in my BV9000 and need to replace it. Can you tell me where to find a kit to fix it.
A professional in my area told me I should get glass, lcd screen and digitizer.
only the glass is broken. The rest works fine.
Which parts do I need to order to fix my glass correctly so I can use my phone again.
My bv5800 just isn't powerful enough anymore. I must fix my bv9000 as soon as possible.
Thanks
Re: Broken Glass
Tue Oct 30, 2018 9:50 pm
Hi there!
Just buy this from here:
https://m.it.aliexpress.com/item/328470 ... 0936089721
Your phone will get back to a full working state ;)
mathatter
Re: Broken Glass
Wed Oct 31, 2018 12:44 am
Is this the same kit? I don't like that site shipping takes many months to arrive. . I bought my phones directly from DOKE.
https://www.amazon.ca/HYYT-BlackView-Di ... ref=plSrch
Re: Broken Glass
Wed Oct 31, 2018 12:26 pm
Yes, it is the same kit.
mathatter
Re: Broken Glass
Wed Oct 31, 2018 1:08 pm
Thank you :)
Users browsing this forum: No registered users and 20 guests
