galdino
don't upadeta A M
Fri Jul 15, 2016 1:00 pm
Dear Admin
for my phone isn't possibile to do update to Android 6.0!!!!
I can't update via OTA!!! Why?
If I use the Zip file to use for local update the smartphone remain when it restart to Lollipop 5.1!!!!
Can you help me?!
reply me soon
Regards
Re: don't upadeta A M
Sat Jul 16, 2016 6:35 am
All rom we provided on forum should be installed with Flash tools.Except those which are special for
local update.
So you need use flash tool and follow the flash manaul to get a update.
Best regards,
Admin
galdino
Sat Jul 16, 2016 10:24 am
Ok
Can you post link for download flash tool?
So I must update telephone only with flash tool and I must use the Firmware in Tar format (t89j...... R15_realised. tar)?
Why I can't update via Ota?
Write me soon please
Thanks
Regards
