mvdwege
Phone stuck in 3G after update to 8.0
Thu Oct 25, 2018 10:25 pm
I updated to 8.0 using local update. I first factory reset the phone, then ran the update from the recovery menu.
After the update my mobile connection is stuck in 3G mode, instead of 4G.
Re: Phone stuck in 3G after update to 8.0
Fri Oct 26, 2018 3:15 pm
Hi there. You have to perform a factory reset also after the Oreo update.
mvdwege
Mon Oct 29, 2018 6:22 am
1. Really? A factory reset after installing the update on a factory reset phone? Does the update itself leave files around that it shouldn't?
2. I apologise, but it appears that 4G works. Either my provider had problems, or something changed in the algorithm that determines availability, because when I left the house the 4G connection turned back on. So you can close this thread.
Mon Oct 29, 2018 8:58 pm
Yes, a factory reset is highly reccommended after EACH update. Glad you have solved your "issue".
