Whip85
Programming of smart key
Fri Oct 19, 2018 6:14 pm
Can the smart key be programmed to be the dedicated camera button (to take photos), instead of using the button on the screen? Thanks
Re: Programming of smart key
Sat Oct 20, 2018 12:59 pm
It can be programmed only to launch apps, for the moment.
Whip85
Sat Oct 20, 2018 1:17 pm
Thank you.
Whip85
Wed Oct 31, 2018 6:14 pm
How difficult would it be to incorporate it with the next update?
IfeBV
Fri Dec 14, 2018 8:33 am
It's currently available. Go to smart key under settings then choose off screen snapshot on any of the predefined clicks.
This works for me as I use one click smart key option to take a snapshot
Users browsing this forum: Baidu [Spider] and 0 guests
