Met95
Firmware Android not update
Fri Oct 19, 2018 9:02 am
hi, I encountered a problem on my BV 8000 pro. I can not update the firmware of the smartphone, is still in version 7.1. I do not know what to do, maybe I have to format the phone?
Re: Firmware Android not update
Fri Oct 19, 2018 3:44 pm
What's your current firmware version?
Met95
Fri Oct 19, 2018 6:02 pm
Android 7.0
Sat Oct 20, 2018 11:51 am
Are you trying to update your phone to Oreo?
Met95
Sat Oct 20, 2018 2:00 pm
Yes
Sun Oct 21, 2018 8:08 pm
The only way to update your device to Oreo is to perform a local update.
You can find a tutorial here:
viewtopic.php?f=192&t=436084
You can download the Oreo ROM here:
viewtopic.php?f=192&t=213272
mkhakk
Sun Oct 21, 2018 8:47 pm
you need full flash using rom 20171227 after update using local update
https://mega.nz/#!ALYXBDxK!KCoHt3WuJ2Rn ... vYfFXGHeBw rom 20171227
https://mega.nz/#!JQBRRKpR!0F0jL-2Sp60n ... 7z8OyEHkh4 Local Update Android 8 Oreo
Met95
Tue Oct 23, 2018 12:44 pm
Thanks
belond
Wed Oct 24, 2018 6:12 am
Met95 wrote:
Thanks
I don't recomend you to update. Too many bugs.
