davi32452
Android 8.0
Fri Oct 12, 2018 12:38 am
Hello, where can I buy a new touchscreen screen ???
I wonder if it will update for Android 8.0 Oreo, if so, when? And if it will take too long ???. Thank you.
Re: Android 8.0
Sat Oct 13, 2018 11:54 pm
Hi there.
You can find spare displays here: https://www.aliexpress.com/premium/blackview-s8-lcd.html?SearchText=blackview+s8+lcd&d=y&tc=ppc&initiative_id=SB_20181013155319&origin=y&catId=0&isViewCP=y
No infos about the release date of the oreo update, at the moment.
MTom18
Re: Android 8.0
Tue Oct 16, 2018 5:10 am
I think there will not be more updates.
MTom18
Re: Android 8.0
Fri Oct 19, 2018 10:49 am
I really need a system upgrade
flavio.ruggieri
Re: Android 8.0
Tue Oct 23, 2018 8:04 pm
I'm tired to wait android 8 or any security update...
MTom18
Re: Android 8.0
Wed Oct 24, 2018 4:15 pm
they will not deal with this type of device. There will not be any updates here. one year old device but no support, no upgrade. before the purchase of the next device.
retribe
Re: Android 8.0
Sun Oct 28, 2018 1:46 pm
Hi all! Me need link to this update.
MTom18
Re: Android 8.0
Wed Oct 31, 2018 12:00 pm
there was no update
retribe
Re: Android 8.0
Sun Nov 04, 2018 5:56 pm
And on the subject - Have the ability to know WHEN there are any updates? People in full use Android 9, at the time of the presentation promised Android 8.1 immediately after the new year(by the way, only because of this I ordered it), and in fact nothing. If you want to increase the level of sales - provide good support. For example, Nokia - take it ONLY because of the SUPPORT. They do not forget about users and support their devices for 3-5 years or even more. And then again released the phone, all the rights and opportunities cut off-they say use a brick until you get bored.
retribe
Re: Android 8.0
Sun Nov 04, 2018 6:00 pm
Well, or at least give the opportunity to obtain root rights. It is likely that some modders will be engaged in the creation of a normal software product.
