MrDong
Question re. BV9500 and USB C cables
Sat Oct 06, 2018 2:28 pm
Hi!
I'm currently on a BV8000 Pro, however I'm considering the BV9500 (non-Pro). But before I decide I'd like to know if the BV9500 still only works with Blackview USB cables, or if now standard USB-C cables can be used.
On the BV8000 Pro, the USB C port is recessed so that normal USB-C cables don't fit mechanically. Which is a pretty strong limitation.
I was hoping that the USB C opening on the BV9500 has been improved so that it's compatible with normal USB C cables.
Anyone knows more about this?
Jay S.
Re: Question re. BV9500 and USB C cables
Tue Oct 09, 2018 11:58 am
I can confirm that regular aftermarket USB-C cables work. Just tested 2 different brands. :mrgreen:
marceloj.bueno
Mon Oct 15, 2018 9:32 am
On test my BV9500 loaded normal with the type "C" cable I use in my motorola G5s
MrDong
Tue Oct 16, 2018 12:39 pm
That's great, thanks! :P
carabao
Sun Sep 08, 2019 9:02 am
An adapter that can connect a usb-c elongated to usb-c classic is in the box (for the Bv9600pro Bv9700pro so I guess it's the same for the BV9500). This makes it possible to use usb-c cables from other brands.
