Zeyard
My accessory works more
Sat Sep 29, 2018 5:03 pm
Hello good night
I have a small problem with an adapter.
I currently have a BlackView 10000 Pro.
My USB-C to Female Jack Adapter does not work anymore.
I went to several stores to see if he owns them and unfortunately none have them.
I would like to know if you can send me back one or how to find one.
Thank you Best regards
Zeyard
Re: My accessory works more
Sun Sep 30, 2018 1:29 am
Hi there!
You can find thousands of them in AliExpress.
Follow this link:
https://m.it.aliexpress.com/wholesale/U ... -c-to-jack
Zeyard
Sun Sep 30, 2018 4:33 pm
Hi the problem I have is that the adapter is bigger than the usb-c one.
I found one in a HiTech center and the fault is that the end is too small, it is not big enough to make it work and back into the charging socket.
Sincerely, Zeyard
Sun Sep 30, 2018 10:49 pm
sorry but i can't understand what your problem is about.
lemme
Mon Oct 01, 2018 1:16 am
hi
you need the usb c long version
you can see it at the charge cable
GrunHerz
Mon Oct 01, 2018 5:36 am
You need an 'long' type-C cable:
example:
https://www.aliexpress.com/item/9mm-Lon ... 08305.html
GrunHerz
Mon Oct 01, 2018 5:57 am
Sorry, I read it wrong. Did you try it with the type-C extender that was packaged in your box?
Something like this:
https://www.aliexpress.com/item/8MM-Lon ... 66246.html
