lucky1guddi
Backup and Restore
Sat Sep 29, 2018 1:23 pm
Hello Sir, I lost my all data after update and reset. I want to know there is any way to save data before formatting. As earlier I used HTC Mobile which provide a function called "Backup & Restore" which create a backup file of all your data and you restore it when you want. Please tell is there any function in Blackview BV8000 Pro???
Re: Backup and Restore
Sun Sep 30, 2018 1:39 am
Google has a backup feature. You'll find it under settings. When your factory reset your phone and start it again, Google will ask you to restore a previous backup. I also reccommend to manual back up puotos, just to be sure.
lucky1guddi
Mon Oct 01, 2018 10:12 am
I did this before installation but it restore only app not data.
Mon Oct 01, 2018 10:13 pm
If "data" are files like documents or photos, just connect the phone on your pc and download them.
lucky1guddi
Tue Oct 02, 2018 5:58 am
I think this is not a valid solution you have to provide a some feature or function which allow us to backup all data
belond
Wed Oct 03, 2018 12:11 pm
mb titanium backup?
Wed Oct 03, 2018 3:55 pm
belond wrote:
mb titanium backup?
titanium requires root. Helium Backup doesn't. ;) you can try it!
