avasiliev91
[TRACKED] Bug with WiFi.
Thu Sep 27, 2018 7:48 pm
I am using Android 8 firmware, and I found a bug with wifi. Wifi is often disconnected, approximately for one second, and connected again. After some time disconnected again and again connected, and again, and again... My CPU MT6757CD. Thank you.
Re: Bug with WiFi.
Sat Sep 29, 2018 12:59 am
Please perform a factory reset and report back. Never heard about such issue in the Oreo ROM. Let's see what other users say about that.
Dphilpott81
Re: Bug with WiFi.
Sat Oct 13, 2018 10:56 am
Mine is constantly dropping out without me realising and smashing my 4g data. Once it's dropped out it will see the WiFi but can't connect without a reset. My colours keep inverting too. What's that about? And when I reset it boots up through the blackview logo twice why? When someone rings the screen in often blank so I can't see who it is. I did a factory reset after upgrading (more like a downgrade, I wouldn't recommend anyone do it.) Little point reporting the issues as blackview can't adress the major issues with this ROM in a timely manner. Maybe Santa will bring me a new phone as the bv8000 pro is useless!
Re: Bug with WiFi.
Sat Oct 13, 2018 11:39 pm
Please open a new thread for each issue...
Dphilpott81
Re: Bug with WiFi.
Sun Oct 14, 2018 7:21 am
Consider this the thread for the WiFi bug. I'd open threads for the other issues if I believed you could do anything about them.
Re: Bug with WiFi.
Sun Oct 14, 2018 10:32 am
If i can't help you to solved them, they need to be fixed at ROM level by the tech team. I can forward such issues to it.
avasiliev91
Re: Bug with WiFi.
Mon Oct 15, 2018 5:36 pm
Report. Factory reset didn't help.
Re: Bug with WiFi.
Tue Oct 16, 2018 10:26 am
ok, forwarding such bug to the tech team!
