Seatravel35
Fingerprint don't fonction
Sat Sep 22, 2018 3:55 pm
On my BV 8000 pro my fingerprint don't fonction. And when I reset the phone is the same... And  my build is 20170803. And I  can't arrived to update, you can help me?
Thanks.
Re: Fingerprint don't fonction
Sun Sep 23, 2018 12:21 am
Unfortunately it looks like an hardware fault. You'll have to contact your seller to have your device replaced under warranty.
Seatravel35
Sun Sep 23, 2018 1:31 pm
Alas I do not remember which website I bought it. So impossible to return it as a guarantee. :-(
Mon Sep 24, 2018 9:41 pm
I'm sorry but there's nothing more i can do to help you.
