Sebbru
Fingerprint overheating.
Fri Sep 21, 2018 10:03 am
an issue occurs since yesterday on my BV8000 pro. There's a overheating located only on the side fingerprint (very very hot). And therefore the battery doesn't last as expected (12 hours with a full load).
Would you have any advice to check where does the problem come from?
Thanks in advance,
Best.
Re: Fingerprint overheating.
Sun Sep 23, 2018 12:23 am
Unfortunately it looks like an hardware fault. You'll have to contact your seller to have your device replaced under warranty.
