kosi
The charger w1 does not charge 5800pro
Thu Sep 13, 2018 1:59 pm
I have a bv 5800 pro for why w1 wireless charger charges only up to 93%
Re: The charger w1 does not charge 5800pro
Thu Sep 13, 2018 10:03 pm
I reccomend you to use the original cable and charger. Everything will work correctly with that.
kosi
Fri Sep 14, 2018 4:31 am
I have all the original but not fill the phone to the end
Sat Sep 15, 2018 10:43 am
Please perform a factory reset and try again. If this doesn't solve your issue, you'll have to contact your seller to have your device replaced under warranty.
