AleP
Problems with gyroscope in Android 7
Tue Sep 04, 2018 6:38 pm
When I open a VR game or an application that use this technology the game works well, but when I try to rotate the phone that is in portrait mode,
moving the phone from left to right everything works fine, but moving from top to bottom the view moves very slowly, almost does not move, could be a problem with the gyroscope? Can it be replaced? Otherwise there is an application to calibrate or fix the non-working sensors, I have Android 7, here is a screenshot of the exact version.
AleP
Re: Problems with gyroscope in Android 7
Wed Sep 05, 2018 10:05 am
Guys Help!
Wed Sep 05, 2018 3:13 pm
i think it is related to such game/app. Can you please try other apps and report back?
AleP
Wed Sep 05, 2018 3:14 pm
I already tried other apps
AleP
Wed Sep 05, 2018 3:19 pm
It can be the magnetic screws? Like in the bv6000 pro? If yes which I have to remove?
Admin?
AleP
Thu Sep 06, 2018 2:32 pm
Admin?
Thu Sep 06, 2018 11:53 pm
Screws are without issue. It looks like a software fault. To rule it out, please perform a factory reset and check if something changes. If not, it could be an hardware issue... but before saying that i  need it to be confirmed from other users aswell...
AleP
Fri Sep 07, 2018 10:41 am
But if it is an hardware issue what can I do?
Sat Sep 08, 2018 12:47 am
Contacting your seller to have your device replaced under warranty.
AleP
Mon Sep 10, 2018 9:51 am
There isn't a spare part!
