sivock
Ruptured earpiece mesh
Wed Aug 29, 2018 1:51 pm
Hello, I did, by mistake, rupture into earpiece mesh by cleaning. I'm working at dusty environment, it was clogged. Can you please advise me where to buy new mesh to this earpiece for replace. I can not find anything on Aliexpress.
Second question: phone with broken mesh on earpiece is still water resistant or not?
Re: Ruptured earpiece mesh
Fri Aug 31, 2018 9:57 am
Hi there!
The mesh isn't available as a spare part, as it is glued to the earpiece speaker.
Here you can find a new earpiece speaker with its mesh: https://m.it.aliexpress.com/item/328467 ... form=msite
The water sealing will be granted even without the mesh ;)
