rafii6311
BV5800 (PRO) Second SIM Slot?
Wed Aug 29, 2018 12:32 pm
Hello.
The Productpage (http://www.blackview.hk/blackview-282/) is telling, there is dual SIM, but i cant find the second SIM slot.
Also, android tells me, its dual SIM.
Where do I find the second slot?
Greetings,
rafii6311
Re: BV5800 (PRO) Second SIM Slot?
Fri Aug 31, 2018 9:18 am
Hi there, can you take pictures of the SIM slot so that I can help you properly?
rafii6311
Sat Sep 01, 2018 11:39 am
I just found that second slot. Its used together with the micro-sd slot.
So its not possible to use micro-sd and SIM-2.
Sun Sep 02, 2018 10:54 pm
Exactly.
