Dennis_320d
[SOLVED] Power button, camera button
Sat Aug 25, 2018 6:55 am
When i first bought the bv8000 pro it was possible to activate the camera when i pushed 2 times the power button. Also It was possible to use the camera button.. Now it stoppen working a while a go. Some body a solution?
Dennis
Re: Power button, camera button
Sat Aug 25, 2018 10:53 pm
Hi there.
Can you please perform a factory reset and report back?
mvss
Tue Aug 28, 2018 6:43 pm
I did but no effect.
I tried to Upgrade to OREO also to fix it but OTA is not working also (Faild as restarted and come to the same version as it was)
Tue Aug 28, 2018 9:37 pm
If a factory reset doesn't solve your issue, it means that it's an hardware fault. In this case I suggest you to contact your seller to have your device replaced under warranty.
mvss
Re: [SOLVED] Power button, camera button
Thu Aug 30, 2018 7:33 am
But it is happened after last update
Fri Aug 31, 2018 10:06 am
Can you please perform a factory reset, tell me what your current software version is and check if the issue is still here?
Amandek
Sun Sep 02, 2018 2:00 pm
The same problem. The camera button doesn't work after updating (20180522).
Sun Sep 02, 2018 10:30 pm
Guys, if the problem is only in the OREO rom, please refer to the correct OREO support subforum:
viewforum.php?f=224
