yasiek_gobb
Camera problem in different apps
Fri Aug 24, 2018 3:49 pm
Hello!
I have a problem with my brand new P10000 Pro. While native camera app works fine, other applications using the camera (for example Google Street View or Magic Viewfinder) don't work well - there is problem with focus and image sizing. These apps are impossible to use in fact.
Is there any solution for my problem?
Regards,
Jan
Re: Camera problem in different apps
Sat Aug 25, 2018 2:14 am
Hi there, can you please perform a factory reset and try again?
