goffi
Problem LCD
Tue Aug 21, 2018 11:45 am
Hello everyone!
I would have a problem, after being finished in cold water my blackview after about an hour has stopped working the screen. the smartphone turns on and charges, but the screen remains black. What could I do to fix it? What could have happened? I also noticed that the back (where the cover of the SIM and the memory card when I try to turn it on becomes really hot)
Thanks to those who will answer me
Re: Problem LCD
Tue Aug 21, 2018 1:08 pm
Hi there, it seems that your unit has some orings missing, as showed here:
viewtopic.php?f=191&t=348815
The first thing I recommend is to contact you seller to have your device replaced under warranty.
If this isn't possible, you can try to replace the LCD unit:
https://m.it.aliexpress.com/wholesale/B ... 00-pro-lcd
goffi
Re: Problem LCD
Tue Aug 21, 2018 3:29 pm
ok, so thanks in theory if I change LCD should work again?
can you suggest me some guide or video explaining how to change the LCD? thank you
Re: Problem LCD
Wed Aug 22, 2018 6:17 pm
Replacing the LCD should do the trick, but I can't know it for sure, nobody can.
You can refer to this YouTube tutorial:
https://youtu.be/_gqXcHqiPQA
