bucksnsk
[SOLVED] touchscreen calibration
Sat Aug 11, 2018 7:12 pm
I flashed phone with wrong firmware, after that I flash it with BV8000Pro_blackview_20170718, and everything is ok, but touchscreen loose calibration, there is an inversion along the X and Y axes. Help me please to calibrate touchscreen.
Re: touchscreen calibration
Sun Aug 12, 2018 2:25 pm
Did you perform a factory reset after flashing the new firmware?
bucksnsk
Fri Aug 31, 2018 3:52 pm
Of course, I did it first. I even did full formatting. Unfortunately the core of that firmware was patched my touchscreen. I tried all the available methods to return the calibration, but none of the firmware returns the touchscreen settings. Need either a kernel with support for calibration of the touchscreen, or a program for flashing the touchscreen from the manufacturer.
Sun Sep 02, 2018 10:55 pm
Did you try also the Oreo firmware?
bucksnsk
Mon Sep 03, 2018 7:00 am
Yes, i try every firmvare, including oreo. Unfotunatly it does not help.
Mon Sep 03, 2018 12:23 pm
I'd try to replace the LCD screen unit with another one.... or contact the seller to have the phone replaced under warranty. It looks more like an hardware fault than a software one.
https://it.aliexpress.com/wholesale?cat ... 00+pro+lcd
bucksnsk
Re: [SOLVED] touchscreen calibration
Sat Sep 15, 2018 6:15 pm
Can you upload lastest version of SP MDT tool cutom edition? To programm display and touch
Mon Sep 17, 2018 9:59 am
I can't help you with that, sorry.
