Matcheu
GPS
Fri Aug 10, 2018 2:35 pm
I have a Blackview A7 model. I want to use the GPS offline so I set the localisation by using only the phone and not the Wifi.
I use the application HERE WeGo and I download maps to use it when I will be offline.
But it doesn't work...the phone don't locate me on the map offline.
Should I use another application or change some phone settings?
Thanks in advance for your answer
Re: GPS
Fri Aug 10, 2018 6:18 pm
Hi there, localization should be enabled too.
Go and test it outdoors ;)
Matcheu
Re: GPS
Mon Aug 13, 2018 7:44 am
The localization is enabled (I didn't forgot  ;) ) but it doesn't work at all offline
Any suggestions?
Re: GPS
Mon Aug 13, 2018 8:56 am
Can you try Google maps navigation in offline mode?
