nyc_cat1997
Blackview bv9000 gives onle Edge (2g) instead of LTE from TMobile
Tue Aug 07, 2018 11:37 pm
Just bought this phone, but sadly can't connect to my LTE Tmobile mobile network. Anything I should do? Please help, otherwise, I need to return this or sell it.
Re: Blackview bv9000 gives onle Edge (2g) instead of LTE from TMobile
Fri Oct 19, 2018 4:01 pm
Hi there!
Unfortunately, as you can see here ( https://www.frequencycheck.com/compatib ... ted-states ) the bv9000 doesn't support 3g/4gLTE frequencies of such phone carrier.
