MrDong
[FEATURE REQUEST] Use the latest subversion of Android for firmware updates
Wed Aug 01, 2018 6:38 am
Hello!
For some reason BV only uses point zero releases of Android (7.0, 8.0) even when there are newer subversions available which also contain a lot of improvements over the point zero release.
Could BV therefore use the current release (which for Android 7 I think is 7.3 and for Oreo it's 8.1) instead of the point zero releases?
Thanks,
Mr Dong
Re: [FEATURE REQUEST] Use the latest subversion of Android for firmware updates
Wed Aug 01, 2018 11:59 pm
Will forward that to the tech team Image
