ConkerVCL
The picture to picture mode is not accessed
Tue Jul 31, 2018 4:53 pm
I have searched for this option in the rom and I have not found it
Re: The picture to picture mode is not accessed
Tue Jul 31, 2018 9:31 pm
Wich apps are you testing it with?
Santpj
Wed Aug 01, 2018 8:19 am
Do you talk about PIP mode?
AleP
Tue Aug 14, 2018 8:05 am
The PIP or Picture in Picture is a function compatible with some applications like YouTube or Google Duo, as you can see in the image, did you find any option in settings?
AleP
Wed Sep 12, 2018 5:33 pm
Admin?
Thu Sep 13, 2018 9:30 pm
it seems to be not supported at the moment.
