Santpj
[SOLVED] Panoramic view
Mon Jul 30, 2018 10:19 am
Does someone see the panoramic option with camera ?
I find that there is less camera's options on 8 than on 7.
Re: Panoramic view
Tue Jul 31, 2018 12:09 pm
As always i suggest to use a more complete camera app, as Opencamera ;)
Santpj
Re: Panoramic view
Tue Jul 31, 2018 2:20 pm
No panorama function with Open camera.
Re: Panoramic view
Tue Jul 31, 2018 9:27 pm
You can find many other apps for this function ;)
Rgaspar
Re: Panoramic view
Tue Jul 31, 2018 11:01 pm
Santpj wrote:
there is a panoramic option with camera and also livephoto. open the camera and then if you have the phone on landscape position, slide from the bottom border up (if you are on normal position, from the left border to right). the opposite opens the configuration menu
Santpj
Re: Panoramic view
Wed Aug 01, 2018 8:17 am
Rgaspar wrote:
Santpj wrote:
Wow thanks a lot Rgaspar...really useful
