VADUS
[SOLVED] Google Drive reserved copying is NOT working.
Mon Jul 30, 2018 9:30 am
The feature is ON, but there is no copy on the Google Drive. The status for all tasks (app. data, call list etc.) is " awaiting for copying". And nothing is going on. After the factory reset - same status.
With best regards,
Vadim
Santpj
Re: Google Drive reserved copying is NOT working.
Mon Jul 30, 2018 10:27 am
No problem for me as you can see on printscreen. The copy worked today
VADUS
Mon Jul 30, 2018 11:19 am
Yes, I can see this. But in my case it doesn't work. I've tried to reboot it several times, checked the Google drive for the copy - but it is empty (the old one from 7.0 was deleted by me).
Santpj
Mon Jul 30, 2018 12:24 pm
May be transfer by WiFi is on and you don't use it
VADUS
Tue Jul 31, 2018 7:03 am
Wi-Fi is ON, and I use it for all purposes. I turned the back up copying off and on several times yesterday, added some new files into the gallery - and it started to back up. First it was only Photos and Videos, and at the end of the day it backed up the rest of the points. After that I finally saw the back up file on the google drive. Thank you for your help. Looks like it solved. I've just not got the reason it happened.
